2018-07-14 8:01 PM
Hi all,
From what I've seen in the documentation, it looks like the bootloader defaults to a bitrate 125kb/s, and can be changed using the speed up command to the max of 1mb/s. It looks like the bootloader always defaults to this, but I figured that I would ask someone who might have direct experience with this - can you change the default bitrate for the embedded bootloader for the STM32F77xx?
#embedded-bootloader #can-bus #stm32f77xx #bootloader2023-06-21 12:22 AM
Hello there goodday,
I was wondering if you've please found a solution to this yet?
Cheers
