Can we use ST Open BootLoader with STM32F446RE Nucleo board ?
ST.10
I've STM32F446RE Nucleo board, which i want to update in the field over USART.
Looks like ST Open Bootloader supports this already. However, the example shared is for STM32G0XX.
I wanted to know if we can use it(ST Open Bootloader) Out-of-box ? and if Not, then can we make minimal changes/port this and use it ?
Imen.D
Hello @Community member​ and welcome to the Community :)
You can customize OpenBL for other products series like STM32F4 series according to your needs:
  • \STM32Cube_FW_G0_V1.x.x\Middlewares\ST\OpenBootloader
  • \STM32Cube_FW_G0_V1.x.x\Projects\STM32G0C1E-EV\Applications\OpenBootloader
I recommend that you refer to the following resources:
 Hope my answer helped you!
Please mark my answer as best by clicking on the "Select as Best" button if it helped.
Imen
Imen
