[Bug report] CubeMX bad Clock/SysTick configuration using LL
Options
2019-11-08 1:24 PM
Using STM32L082KZUx MCU with CubeMX 5.4.0 and Keil.
Wanted to use 16MHz with LL on RCC library but having bad clock configuration, SysTick is maybe 10 time faster. If I change on RCC to HAL, when it works as it should - Systick gets to be correct 1 ms.
Maybe someone has same issues and knows where to fix in LL ?
Thanks for Your time!
Labels:
STM32Cube MCU Packages
STM32L0 Series
0 REPLIES 0
