Bug CubeMX/F0 - Can not configure pin
elijah
Posted on October 08, 2015 at 23:02
CubeMX v4.10.1, everything is updated.
I'm trying to configure PA0 & PA1  to GPIO Output, Open Drain, Pull-up.
CubeMX does not save the configuration and does not modify my project properly.
#bug #stm32cube
Posted on October 09, 2015 at 17:39
Hi m.e,
I confirm that the behaviour is aleatory when user change pin configuration, sometimes the modification is generated correctly in the code and sometimes not.
Now, I recommend you to save your modifications by ticking ''Apply'' button. And the issue is reported for investigation.
-Shahrzad-
