AN3990: Upgrade STM32F4DISCOVERY board firmware using a USB key.
magnus2
Posted on May 06, 2016 at 15:57
Hi ,
I'm trying to Upgrade STM32F4DISCOVERY board firmware using a USB key, like
AN3990.
At the USB key I have ''STM32F4-Discovery_MEMS_0x08008000.bin'' renamed to
''image.bin''
I'am using .dfu and .bin form :
https://github.com/rowol/stm32_discovery_arm_gcc/tree/master/STM32F4-Discovery_FW_V1.1.0/Project/FW_upgrade/Binary
#an3990-bootloader-usb-key
3 REPLIES 3
Posted on May 06, 2016 at 16:40
I suspect you'll want to build the code yourself and use a debugger?
You can also add diagnostic output via a serial port or SWV to understand what's going on internally.
Try other flash drives, I think the read me alludes to certain drives not working due to their design, etc. ST has historic problems dealing with storage devices >2-4GB
magnus2
Posted on May 07, 2016 at 21:21
Hi Clive1!
Thanks for your answer!
Do you know how to change the source code of AN3990 to make it support bigger USB keys? For example 4 GB.
Do you know where to find a CooCox project of the AN3990?
Magn
Posted on May 08, 2016 at 02:37
Just skimmed the MSC HOST code, looks to handle block rather than byte offsets, so should work >2GB
Sorry I don't use CooCox
