Alternative ethernet driver for the NUCLEO-H7S3L8
potatobandit
I am trying to prototype ethernet on the NUCLEO-H7S3L8 eval board. When enabling ethernet through CubeMx using the same configuration I've used on the NUCLEO-H563ZI, the ethernet driver fails initialization.
Is there an alternative Ethernet driver that is recommended or a better eval board I should use?
1 REPLY 1
Pavel A.
Evangelist III
This board has LwIP examples. Please start from one of the examples and make it work on your board before creating a new project from scratch (.ioc)
