2024-01-27 11:57 AM - edited 2024-01-27 11:59 AM
Hi, I'm using ADC1 and ADC2 of a STM32F303RE in dual regular simultaneous mode. Each ADC should sample 5 independent channels and a sampling cycle is triggered by software, so I don't use continuous mode.
I do get DMA interrupts and everything seems to work fine, except that the buffer which should contain the ADC samples which got transferred by DMA is untouched - no results transferred.
adc.c is:
void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_MultiModeTypeDef multimode = {0};
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Common config
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
hadc1.Init.Resolution = ADC_RESOLUTION_10B;
hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 5;
hadc1.Init.DMAContinuousRequests = ENABLE;
hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure the ADC multi-mode
multimode.Mode = ADC_DUALMODE_REGSIMULT;
multimode.DMAAccessMode = ADC_DMAACCESSMODE_12_10_BITS;
multimode.TwoSamplingDelay = ADC_TWOSAMPLINGDELAY_1CYCLE;
if (HAL_ADCEx_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_1;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SingleDiff = ADC_SINGLE_ENDED;
sConfig.SamplingTime = ADC_SAMPLETIME_61CYCLES_5;
sConfig.OffsetNumber = ADC_OFFSET_NONE;
sConfig.Offset = 0;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_2;
sConfig.Rank = ADC_REGULAR_RANK_2;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_3;
sConfig.Rank = ADC_REGULAR_RANK_3;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_4;
sConfig.Rank = ADC_REGULAR_RANK_4;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_TEMPSENSOR;
sConfig.Rank = ADC_REGULAR_RANK_5;
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
/* ADC2 init function */
void MX_ADC2_Init(void)
/* USER CODE BEGIN ADC2_Init 0 */
/* USER CODE END ADC2_Init 0 */
/* USER CODE BEGIN ADC2_Init 1 */
/* USER CODE END ADC2_Init 1 */
/** Common config
hadc2.Instance = ADC2;
hadc2.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
hadc2.Init.Resolution = ADC_RESOLUTION_10B;
hadc2.Init.ScanConvMode = ADC_SCAN_ENABLE;
hadc2.Init.ContinuousConvMode = DISABLE;
hadc2.Init.DiscontinuousConvMode = DISABLE;
hadc2.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc2.Init.NbrOfConversion = 5;
hadc2.Init.DMAContinuousRequests = DISABLE;
hadc2.Init.EOCSelection = ADC_EOC_SEQ_CONV;
hadc2.Init.LowPowerAutoWait = DISABLE;
hadc2.Init.Overrun = ADC_OVR_DATA_PRESERVED;
if (HAL_ADC_Init(&hadc2) != HAL_OK)
Error_Handler();
sConfig.Offset = 0;
if (HAL_ADC_ConfigChannel(&hadc2, &sConfig) != HAL_OK)
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
sConfig.Channel = ADC_CHANNEL_5;
Error_Handler();
/* USER CODE BEGIN ADC2_Init 2 */
/* USER CODE END ADC2_Init 2 */
static uint32_t HAL_RCC_ADC12_CLK_ENABLED=0;
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
if(adcHandle->Instance==ADC1)
/* USER CODE BEGIN ADC1_MspInit 0 */
/* USER CODE END ADC1_MspInit 0 */
/* ADC1 clock enable */
HAL_RCC_ADC12_CLK_ENABLED++;
if(HAL_RCC_ADC12_CLK_ENABLED==1){
__HAL_RCC_ADC12_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**ADC1 GPIO Configuration
PC0 ------> ADC1_IN6
PA0 ------> ADC1_IN1
PA1 ------> ADC1_IN2
PA2 ------> ADC1_IN3
PA3 ------> ADC1_IN4
GPIO_InitStruct.Pin = ADC9_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
HAL_GPIO_Init(ADC9_GPIO_Port, &GPIO_InitStruct);
GPIO_InitStruct.Pin = ADC0_Pin|ADC1_Pin|ADC2_Pin|ADC3_Pin;
/* ADC1 DMA Init */
/* ADC1 Init */
hdma_adc1.Instance = DMA1_Channel1;
hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
hdma_adc1.Init.Mode = DMA_CIRCULAR;
hdma_adc1.Init.Priority = DMA_PRIORITY_LOW;
if (HAL_DMA_Init(&hdma_adc1) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc1);
/* USER CODE BEGIN ADC1_MspInit 1 */
/* USER CODE END ADC1_MspInit 1 */
else if(adcHandle->Instance==ADC2)
/* USER CODE BEGIN ADC2_MspInit 0 */
/* USER CODE END ADC2_MspInit 0 */
/* ADC2 clock enable */
/**ADC2 GPIO Configuration
PA4 ------> ADC2_IN1
PA5 ------> ADC2_IN2
PA6 ------> ADC2_IN3
PA7 ------> ADC2_IN4
PC4 ------> ADC2_IN5
GPIO_InitStruct.Pin = ADC4_Pin|ADC5_Pin|ADC6_Pin|ADC7_Pin;
GPIO_InitStruct.Pin = ADC8_Pin;
HAL_GPIO_Init(ADC8_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN ADC2_MspInit 1 */
/* USER CODE END ADC2_MspInit 1 */
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
/* USER CODE BEGIN ADC1_MspDeInit 0 */
/* USER CODE END ADC1_MspDeInit 0 */
/* Peripheral clock disable */
HAL_RCC_ADC12_CLK_ENABLED--;
if(HAL_RCC_ADC12_CLK_ENABLED==0){
__HAL_RCC_ADC12_CLK_DISABLE();
HAL_GPIO_DeInit(ADC9_GPIO_Port, ADC9_Pin);
HAL_GPIO_DeInit(GPIOA, ADC0_Pin|ADC1_Pin|ADC2_Pin|ADC3_Pin);
/* ADC1 DMA DeInit */
HAL_DMA_DeInit(adcHandle->DMA_Handle);
/* USER CODE BEGIN ADC1_MspDeInit 1 */
/* USER CODE END ADC1_MspDeInit 1 */
/* USER CODE BEGIN ADC2_MspDeInit 0 */
/* USER CODE END ADC2_MspDeInit 0 */
HAL_GPIO_DeInit(GPIOA, ADC4_Pin|ADC5_Pin|ADC6_Pin|ADC7_Pin);
HAL_GPIO_DeInit(ADC8_GPIO_Port, ADC8_Pin);
/* USER CODE BEGIN ADC2_MspDeInit 1 */
/* USER CODE END ADC2_MspDeInit 1 */
main.c is, so DMA does get initialized before the ADC.
MX_GPIO_Init();
MX_DMA_Init();
MX_ADC1_Init();
MX_ADC2_Init();
ADC is initially started with...
HAL_StatusTypeDef AdcScreenSensor::start(void) {
// start the slave
HAL_StatusTypeDef ret = HAL_ADC_Start(m_hadc_slave);
ETL_ASSERT(ret == HAL_OK, DriverException(E010204_UNABLE_TO_START_ADC));
// start the master
ret = HAL_ADCEx_MultiModeStart_DMA(m_hadc_master, m_sample_buffer/*._buffer*/, SCREEN_WIDTH / 2/*SAMPLE_BUFFER_SIZE*/);
ETL_ASSERT(ret == HAL_OK, DriverException(E010206_UNABLE_TO_START_ADC_MULTIMODE));
return ret;
Consecutive cycles are started with...
HAL_StatusTypeDef AdcScreenSensor::restart(void) {
// restart the slave
// restart the master
ETL_ASSERT(ret == HAL_OK, DriverException(E010211_UNABLE_TO_RESTART_ADC_MULTIMODE));
return ret;
And after each cycle the ADC is stopped with...
HAL_StatusTypeDef AdcScreenSensor::stop(void) {
HAL_StatusTypeDef ret = HAL_ADC_Stop_DMA(m_hadc_slave);
ETL_ASSERT(ret != HAL_ERROR, DriverException(E010202_UNABLE_TO_STOP_ADC_MULTIMODE_DMA));
ret = HAL_ADCEx_MultiModeStop_DMA(m_hadc_master);
ETL_ASSERT(ret == HAL_OK, DriverException(E010202_UNABLE_TO_STOP_ADC_MULTIMODE_DMA));
return ret;
The ISR for the DMA interrupts is...
void AdcScreenSensor::HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc) {
ETL_ASSERT_OR_RETURN(instance != nullptr, DriverException(E010210_ADC_NOT_INITIALIZED));
if (hadc == instance->m_hadc_master) {
instance->copyFull();
instance->m_isr_callback_queue->push_from_unlocked(0);
The ISR does get called and the calling stack clearly shows that DMA is called properly:
However, the result buffer which should be filled with 5 x 32 bits of data is left untouched.
Fun fact: Calling HAL_ADCEx_MultiModeGetValue(m_hadc_master) in the ISR does give me the last result.
DMA settings for ADC1 are...
...and DMA settings for ADC2 are empty, so only one DMA channel is used:
I'm lost and the HAL documentation regarding dual regular simultaneous mode is almost non-existing. Any ideas ?
2024-01-27 2:59 PM
Ok, I found the reason - my ADC wrapper was not that singleton as it should be.
2024-01-27 2:59 PM
