A Mistake Found in HAL Library
Laurie1
Function "PWM Generation CH2N" can not work, channel CH2N don't output PWM signal. But after I changed "tmpccer &= ~TIM_CCER_CC2NE;" to "tmpccer |= TIM_CCER_CC2NE;" (in file stm32h7xx_hal_tim.c), it works well.
Hoping developers of HAL library will fix this mistake soon.
Guru
The complementary timer channels are started with HAL_TIMEx_PWMN_Start. No bug here.
4 REPLIES 4
Guru
Laurie1
I called "HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2);", did you mean that?
Could you please tell me which chip do you use? Thank you.
Guru
Nope, I mean HAL_TIMEx_PWMN_Start.
https://github.com/STMicroelectronics/STM32CubeH7/blob/ccb11556044540590ca6e45056e6b65cdca2deb2/Drivers/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_tim_ex.c#L1074
To start channel 2N:
HAL_TIMEx_PWMN_Start(&htim1, TIM_CHANNEL_2);
I use many different chips.
Laurie1
Thank you very much! I found that founction in file "stm32h7xx_hal_tim_ex.h" and solve my problem :)
