Where is the "Debug Authencication" ?
MQi.1
Senior II
I used a MB2032-WB09-B02 on MB1801D for several times, flash in CubeIDE was always OK, though debug prompted error read data every time, then the next day when I used it again, it didn't work, I couldn't flash image into neither in IDE nor Prog, the prompt:
my question is: how to discovery using Debug Authentication?
1 REPLY 1
Imen.D
Hello @MQi.1 ,
Check the solder-bridges and jumpers positions (JP2 ON, JP1 on USB_STLK [1-2] on the MB1801 board.)
Switch SW1 should be on the 3V3 power supply (switch on position [1-2]) on the MB1801 board.
Make sure to follow the settings described in the UM3345 STM32WB09 Nucleo-64 board (MB1801 and MB2032) in Getting started section and Table 12. Solder bridges for MB1801.
Imen
