When i power on the board with BOOT0 pin to 1 the micro goes in BOOT mode (I think) but an infinite NRST reset loop is triggered every 30 milliseconds with a duration of 20 microseconds. Can you help me? Magnani
HTitalia
i am using an STM32L4R9ZGJ6
4 REPLIES 4
Uwe Bonnes
Principal II
Check option bytes is hardware watchdog is enabled.
HTitalia
Thanks for the answer, i checked the OPTR register but the hardware watchdog is disable, all option bit are right
Uwe Bonnes
Principal II
So check you schematic fot logical errors and your board fort shorts and opens.
VCAP pins and capacitors
VDDA
OSCOUT
