What is the purpose of included Vref- pin in big packages(STM32F722IEK6). Can I provide negative voltage to it and measure +- signals with adc?
NChor.1
Provides for a quieter ground return to the supply/regulator.
No, can't be negative relative to MCU, limits described in the data sheet for sure.
4 REPLIES 4
Is there other STM MCU that can measure +- signals?
No, perhaps better to use an external with better range/precision, or signal conditioning to compress into the range of the MCU
Harvey White
Senior III
allows differential inputs.
absolutely cannot be negative, must be within the voltage limits for any pin.
