2021-12-11 06:00 AM
2021-12-11 06:07 AM
Provides for a quieter ground return to the supply/regulator.
No, can't be negative relative to MCU, limits described in the data sheet for sure.
2021-12-11 06:07 AM
2021-12-11 06:15 AM
Is there other STM MCU that can measure +- signals?
2021-12-11 06:52 AM
No, perhaps better to use an external with better range/precision, or signal conditioning to compress into the range of the MCU
2021-12-11 07:14 PM
allows differential inputs.
absolutely cannot be negative, must be within the voltage limits for any pin.
