Apr 17, 2024 7:57 AM UTC
STM32F407 clock setup using registers
I ty to configure the clock setup of stm32f407 board using registers .
But I am not getting the values of Registers in the SFR while debugging.
Since I am enabling the GPIOD in the AHB1ENR registers but still I am not getting the value during the debug.
Apr 17, 2024 7:58 AM UTC
Andrew Neil
Apr 17, 2024 8:00 AM UTC
Try using CubeMX to generate the setup you require, then extract the register values from that.
Please use this button to properly post source code:
Apr 17, 2024 8:09 AM UTC
#include "Mcu.h"
#include"stm32f407xx.h"
int main()
	Mcu_Init(&Mcu_ConfigSet[0]);
	Mcu_InitClock(0);
	while(1)
#include <Mcu_Internal.h>
PwrConfigType PWR_ConfigSet[1] =
				/*PwrCRConfgVal*/
						VOS_SCALE_1 ,
						FPDS_NOT_POWER_DOWN ,
						DBP_DISABLED,
						PLS20V ,
						PVDE_DISABLED ,
						PDDS_STOP_MODE ,
						LPDS_STOP_MODE,
				/*PwrCSRConfgVal*/
						BRE_DISABLED ,
						EWUP_NOT_WAKEUP,
FLASHConfigType FLASH_ConfigSet[1]=
				/*FLASHACRConfgVal*/
						DCRST_NOT_RESET ,
						ICRST_NOT_RESET,
						LATENCY_FIVE_STATE,
						DCEN_ENABLED,
						ICEN_ENABLED,
						PRFTEN_ENABLED,
McuClockConfigType Mcu_ClockConfigSet[1] =
		/*Mcu_ClockConfigSet-1*/
				/*McuCRConfgVal*/
						/*HSION */
						HSION_OFF,
						/*HSITRIM */
						HSITRIM,
						/*HSEON */
						HSE_ON,
						/*HSEBYP */
						HSEBYP_OFF,
						/*CSSON */
						CSS_OFF,
						/*PLLON */
						PLL_ON,
						/*PLLI2SON */
						PLLI2S_OFF,
				/*McuPLLCFGRConfgVal*/
						/*PLLM*/
						PLLM_8,
						/*PLLN*/
						PLLN_336,
						/*PLLP*/
						PLLP_2,
						/*PLLSRC_HSE*/
						PLLSRC_HSE,
						/*PLLQ*/
						PLLQ_7,
				/*McuCFGRConfgVal*/
						PRE2_AHB_2,
						PRE1_AHB_4,
						HRPE_SYSCLK_1,
						SW_PLL ,
						MCO2_SYSCLK,
					 MCO2PRE_2 ,
						MCO1PRE_2 ,
						I2SSRC_PLL ,
						MCO1_HSE ,
			 		RTC_PREHSE_1,
				/*McuCIRConfgVal*/
						PLLI2SRDYIELI_DISABLED,
						PLLRDYIELI_DISABLED ,
						HSERDYIEI_DISABLED ,
						HSIRDYIEI_DISABLED ,
						LSERDYIEI_DISABLED ,
						LSIRDYIEI_DISABLED,
				/*McuAHB1ENRConfgVal*/
						OTGHSULPIEN_DISABLED,
						OTGHSEN_DISABLED,
						ETHMACPTPEN_DISABLED,
						ETHMACRXEN_DISABLED,
						ETHMACTXEN_DISABLED,
						ETHMACEN_DISABLED,
						DMA2EN_DISABLED,
						DMA1EN_DISABLED,
						CCMDATARAMEN_DISABLED,
						BKPSRAMEN_DISABLED,
						CRCEN_DISABLED,
						GPIOIEN_DISABLED,
						GPIOHEN_DISABLED,
						GPIOGEN_DISABLED,
						GPIOFEN_DISABLED,
						GPIOEEN_DISABLED,
						GPIODEN_ENABLED,
						GPIOCEN_DISABLED,
						GPIOBEN_DISABLED,
						GPIOAEN_DISABLED
				/*McuAHB2ENRConfgVal*/
						OTGFSEN_DISABLED,
						RNGEN_DISABLED,
						HASHEN_DISABLED,
						CRYPEN_DISABLED,
						DCMIEN_DISABLED,
				/*McuAPB3ENRConfgVal*/
						FSMCEN_DISABLED,
				/*McuAPB1ENRConfgVal*/
						DACEN_DISABLED,
						PWREN_ENABLED,
						CAN2EN_DISABLED,
						CAN1EN_DISABLED,
						I2C3EN_DISABLED,
						I2C2EN_DISABLED,
						I2C1EN_DISABLED,
						UART5EN_DISABLED,
						UART4EN_DISABLED,
						USART3EN_DISABLED,
						USART2EN_DISABLED,
						SPI3EN_DISABLED,
						SPI2EN_DISABLED,
						WWDGEN_DISABLED,
						TIM14EN_DISABLED,
						TIM13EN_DISABLED,
						TIM12EN_DISABLED,
						TIM7EN_DISABLED,
						TIM6EN_DISABLED,
						TIM5EN_DISABLED,
						TIM4EN_DISABLED,
						TIM3EN_DISABLED,
						TIM2EN_ENABLED,
				/*McuAPB2ENRConfgVal*/
						TIM11EN_DISABLED,
						TIM10EN_DISABLED,
						TIM9EN_DISABLED,
						SYSCFGEN_DISABLED,
						SPI1EN_DISABLED,
						SDIOEN_DISABLED,
						ADC3EN_DISABLED,
						ADC2EN_DISABLED,
						ADC1EN_DISABLED,
						USART6EN_DISABLED,
						USART1EN_DISABLED,
						TIM8EN_DISABLED,
						TIM1EN_DISABLED,
				/*McuBDCRConfgVal*/
						BDRST_RESET_NOTACTIVATED ,
						RTCEN_CLOCK_DISABLED ,
						RTCSEL_NO ,
						LSEBYP_NOT_BYPASSED ,
						LSEON_OFF,
				/*McuCSRConfgVal*/
						LSION_OFF,
				/*McuSSCGRConfgVal*/
						SSCGEN_DISABLE,
						SPREADSEL_CENTRE,
				/*McuPLLI2SCFGRConfgVal*/
						PLLI2SR2 ,
						PLLI2SN0,
Mcu_ConfigType Mcu_ConfigSet[1]=
				&PWR_ConfigSet[0],
				&Mcu_ClockConfigSet[0],
				&FLASH_ConfigSet[0]
This is my code for stm32f407 board for the clock setup using registers. can you look at this and help me with this.
Andrew Neil
Apr 17, 2024 8:18 AM UTC
You haven't showed the code for your Mcu_InitClock() function.
Again, why not create a working setup using CubeMX - then take the required settings from that?
Then debug your code against the Cube code.
Just on a question of style why:
				&PWR_ConfigSet[0],
				&FLASH_ConfigSet[0]
instead of just
				PWR_ConfigSet,
				Mcu_ClockConfigSet,
				FLASH_ConfigSet
