2025-07-16 11:54 PM - last edited on 2025-07-17 12:15 AM by Andrew Neil
Hello ST,
Can you confirm if the hardware of the https://www.st.com/en/evaluation-tools/steval-66gymai.html#overview is compatible with the https://www.st.com/en/evaluation-tools/stm32n6570-dk.html. Can i connect them together with the FCC cable (MIPI-CSI connector) ?
Is this the correct driver https://github.com/STMicroelectronics/x-cube-isp/tree/main/Middlewares/ST/STM32_Camera_Middleware/sensors/vd6g that i should use to work with the VD66GY on the STM32N6.
Thank you.
2025-10-14 1:25 AM
hi
the STM32N6 currently supported cameras list here:
in the list V66GY is supported. the 2 hardware is compatible, you can try to connect the camera with the N6 DK board.
2025-10-14 1:25 AM
hi
2025-10-14 4:44 AM
yes, it works with the stm32n6570-dk
