st-link/v2 - Programming Error
liberamos
Posted on March 02, 2015 at 14:17
i'm trying to load an .hex file into an ARM
STM32F103R6 with St-link/V2
 but there is something that doesn't work (see attached img).
Could you help me pls?
#st-link/v2-programming-issue
4 REPLIES 4
Posted on March 02, 2015 at 17:25
Says the erase failed. Guess I'd look at the board for issues, either design or construction. No real detail provided.
Does a bulk/mass erase work independently of the download?
liberamos
Posted on March 02, 2015 at 17:37
Thanks a lot for reply.
The board is good, we tried programming some PCBA with Keil uViusion4 and Keil uLink2 and all works good.
I tried to erase the chip with STM32 ST-Link Utility and it work fine, then i tried to erase sectors and some sectors is not erased (the system tell me ''Verify the memory protection'').
Posted on March 02, 2015 at 17:54
If the ST-LINK has current firmware, and it's not a SWD/JTAG issue, or one of the other connection options, you'll need to find someone at ST to discuss the issue with you.
liberamos
Posted on March 03, 2015 at 11:03
OK, I'll contact ST.
thanks a lot.
