ST-Link/v2 - ''Encountered an Improper Argument''
erikvp99
Posted on October 31, 2013 at 01:27
I am using the ST-Link/v2 for the first time.  I tried loading firmware and when I select ''Program Verify'' and then select the .hex file, I immediately get a pop up window with the following message, ''Encountered an Improper Argument''.  What does this mean?
#st-link
Amel NASRI
Posted on November 01, 2013 at 13:15
Hi Eric,
You are using the ST-LINK Utility tool, true?
What product are you trying to program?
Do you face any issue when you use only ''Program'' (without verification)?
-Mayla-
