ST-LINK on STM32L552E-EVAL board
‎2024-10-24 9:09 AM - last edited on ‎2024-10-24 12:42 PM by Tesla DeLorean
I have a evaluation board STM32L552E-EVAL, and I would like to know what is this part used for ?
I see 2 pins (USB_D_N and USB_D_P) that connect to the STM32F103CBT6
What is it for ? To program the component and debug. Thank you for your answer
Yann DO
ST-Link
‎2024-10-24 12:46 PM
@DYann.1 wrote:the STM32F103CBT6
What is it for ?
That is the ST-Link - for programming and debugging
via: https://www.st.com/en/evaluation-tools/stm32l552e-ev.html#documentation
‎2024-10-24 11:36 AM
It is ESD protection
‎2024-10-24 12:39 PM
@DYann.1 wrote:what is this part used for ?
What part - the USBLC6-2 ?
Its datasheet tells you what it's for:
https://www.st.com/resource/en/datasheet/usblc6-2.pdf
via: https://www.google.com/search?q=usblc6-2sc6
‎2024-10-24 12:44 PM
I'd have thought this would have been readily obvious, the on-board debugger. ST-LINK/V2-1
Provides the USB CDC connectivity to a L552 UART, and an USB MSC to drag-n-drop firmware binaries, as originally used by mbed
What is it for ?
‎2024-10-24 1:54 PM
Thank you
‎2024-10-24 2:03 PM
Thank you, in fact I would like to program and debug via J-LINK SEGGER. In fact, on my real card I do not use the ST-LINK (for consumption). Do you know where I can find the information to configure the J-LINK to be able to work under STMCubeIDE ? I can see some information but it's not very clear for my.
Thank you
‎2024-10-24 2:38 PM
I'd imagine under debugger settings, perhaps videos on YouTube if reading not strong
See this if you want it to present as a "J-Link OB"
https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/
‎2024-10-24 2:56 PM
I will look at this link. I can work with the J-LINK with my STM32L552xx evaluation card but I still need the ST-LINK usb connector otherwise it doesn't work under STM32CubeIDE. I just need to select J-LINK :
So according to your previous answer, I guess ST-LINK usb is for programming and J-LINK is for DEBUG, right ? If I remove the ST-LINK usb then it does not work.
‎2024-10-24 3:42 PM
@DYann.1 wrote:I guess ST-LINK usb is for programming and J-LINK is for DEBUG, right ?
No, not at all.
Both J-Link and ST-Link are full programmers and debuggers.
But this is a different question from your original (solved) one - please start a new thread for a new question.
