pwm complementary Mode not getting Invertered output ie HAL_TIMEx_PWMN_Start(&htim1, TIM_CHANNEL_1);
thannara123
I am using STM32f103 Controller ,
In that i am trying to make complementary PWM output by using Timer 1
TIM1 with PWM Generation CH1 CH1N ,
But only gets the wave from this HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1); function not getting other inverted signel from the pin PA8
not getting PWM signal on PA7
what is the wrong with me
similar doubt thread is here https://community.st.com/t5/stm32-mcus-products/how-to-only-output-stm32-pwm-ch1n-and-disable-ch1-in-quot-pwm/td-p/123113
But i didnt understood the problem
4 REPLIES 4
SRedd.5
Senior III
This is not required I think.
thannara123
It is worked on CH2 AND CH2N.
WHAT WILL BE THE REASON
please post the complete code.
waclawek.jan
Read out and check/post content of TIM and relevant GPIO registers.
