2025-03-30 11:01 AM - last edited on 2025-03-30 12:27 PM by mƎALLEm
Hi i want to enable Power module (Generally PWR EN) on which bus i can enable this bit in can of NUCLEO-H723ZG
as for reference manual is used RM0468
Also if you find this please give me link to that data sheet and secion number as i can not find it in this.
2025-08-11 1:35 AM
I think what you're looking for is the PWR Control register, You can find the complete PWR register map, including all bit definitions, in paragraph 6.8.10 in the RM
As per the datasheet, this is the link
Hope that helps!
