April 14, 2026
WiFi or WiFi+BT modules architecture and parts recommendations
We are looking for a WiFi module or preferably a WiFi + BT module to be used in a battery-operated device where audio files are recorded onto a uSD card and whenever required they are downloaded through WiFi or BT link to a PC. For context, the audio files are 20MB in size.
These are the main specs:
- pre-certified module: WiFi or WiFi+BT
- highly reliable for mass production
- uSD card interface (specific for audio and files)
- means to record and play back the audio files
- low-power
- compact & SMD
- straightforward to integrate from a firmware perspective (library available) and well supported in terms of documentation and ecosystem.
Could you please make recommendations:
- for such suitable modules?
- for alternative system architecture using ST products and ecosystem to implements such device?
Thank you
Ricko
Andrew Neil
Andrew NeilBest answer
ST's only module with both WiFi and BLE is the ST67W series:
https://www.st.com/en/wireless-connectivity/wi-fi-products.html
This is a coprocessor module - it needs a separate Host microcontroller.
ST's MCUs with built-in BLE are the STM32WBx series:
https://www.st.com/en/microcontrollers-microprocessors/stm32-wireless-mcus/products.html
There are no MCUs with WiFi.
Andrew Neil
RickoAuthor
April 14, 2026
Thank you @Andrew Neil
what would you recommend as the lowest cost micro that can record to uSD and playback audio files?
Thank you
Andrew Neil
An SD card (micro or otherwise) can be accessed via SPI - so any microcontroller with SPI ...
https://www.st.com/en/development-tools/st-mcu-finder-pc.html
https://www.st.com/en/development-tools/stm32-finder.html
https://www.st.com/content/st_com/en/stm32-mcu-developer-zone/mcu-portfolio.html
Distributors often have good parametric search tools ...
Andrew Neil
Follow-on question focussing on audio capabilities split to new thread:
Microcontroller with some kind of audio I/O capability ?
@Ricko If Audio is key, note that ST Microcontrollers only have BLE - not "Classic" BT.
Most "Bluetooth" audio is "Classic".
If the WiFi/BLE part of your question is now resolved, please mark the solution.
RickoAuthor
April 16, 2026
