Need help in adding Micro USB to STM32NUCLEOF302R8
deepakelango05
I want to Implement USB Device in STM32NUCLEOF302R8.
As you know the STM32NUCLEOF302R8 supports USB but it doesn't have micro-usb port for connceting a USB cable.
Even after reading  Even after reading USB implementation on AN4879  I am not getting how to connect micro-USB to STM32NUCLEOF302R8.
I need some help with how to make conncetion of MICRO-USB to STM32NUCEOF302R8 ?
Andrew Neil
Where, exactly, are you stuck with that?
From the Nucleo board's User Manual and/or schematics, find where the USB signals appear on the board's connection pins. Attach your USB connector there!
Also check the above documentation for any links (or solder-bridges), etc, that need to be made or broken to allow the USB to work
@Andrew Neil   I am struck at connecting The VCC and ID pins and in F4 series the termination already there but in F302 I am not sure how to handle it? and how Vcc and ID pins are connected I am sure?
NOTE:  I am trying to connect Micro USB B socket to NUCLEO-F302R8
