2019-12-16 11:01 PM
I need to mount a Nucleo-64 development PCB as a plug-in to a PCB motherboard and need to locate the mechanical Gerber files so that I can create a footprint in Eagle CAD.
2019-12-17 05:45 AM
Nucleo-64 gerber files can be downloaded from here:
https://www.st.com/resource/en/board_manufacturing_specification/nucleo_64pins_gerber.zip
2019-12-17 05:45 AM
2020-01-06 11:26 PM
Thank you for your reply but I cannot open these Gerbers, besides which I would like a mechanical dimension drawing with PCB dimensions in mm if possible....
2020-01-07 02:48 AM
You can use the free tool gerbv to open the Gerber files and take all dimensions in mm/mils/imperial.
