Inconsistent package naming in Cube32MX - MCU Selector
‎2023-02-05 02:52 AM
What's the difference between "LQFP32" and "LQFP 32 7x7x1.4mm"? Probably they both refer to the very same package?. A similar discrepancy appears for a lot of other packages, too. (For WLCSP it's a different matter.)
STM32C0 Series
STM32CubeMX
‎2023-08-09 04:05 AM - edited ‎2023-08-09 04:06 AM
Hello @Andreas Bolsch ,
You can refer to the datasheet DS13867 section 6.4 LQFP32 package information. This LQFP is a 32-pin, 7 x 7 mm low-profile quad flat package. Maybe, it seemed unclear in the CubeMX selector, but for now, it is already fixed.
Thank you
Thank you
