I replaced the stm32f407ve chip on my board but it didn't work
‎2024-09-08 9:27 PM
on my mks monster8 v2 3d printer control board using stm32f407ve chip it was damaged specifically gnd pin and vcc pin are connected, i bought another chip and soldered it to the board, however when plugging in usb it does not recognize com port, i tried connecting with my stlink v2 it still displays the necessary parameters and can read and write, i loaded blink led program and it works however when loading printer firmware specifically marlin it does not work and usb connected to computer does not recognize com port
STM32F4 Series
‎2024-09-09 8:25 AM
The failure is perhaps more involved. You'll need to get a schematic and work through the circuit. You've likely damaged the supply, check voltages and components in the path.
Perhaps find a repair technician familiar with the board, or find forums dedicated to support of the board,
‎2024-09-09 2:33 AM
Hello @duong and welcome to the community;
As you have replaced the MCU, double check the hardware, mainly the USB part.
‎2024-09-09 7:59 AM
I checked the hardware again, the two pins d+ and d- of the usb are connected directly to the microcontroller through the two corresponding pins PA12 PA11, it is soldered exactly according to the pin out of the board manufacturer
‎2024-09-09 8:25 AM
‎2024-09-09 9:05 PM
maybe you are right, i measured the resistance on pin pa12 with gnd, the value is 6.5 ohm and pa11 with gnd, the resistance is up to Mohm
‎2024-09-09 9:06 PM
pa12 is 6.5 kohm
‎2024-09-15 4:37 AM
i replaced a new chip loaded the program with st link and tried with the code the led blinking works fine but still can not connect to usb, i hold boot 0 and power on bootloader mode still works, did i forget some step, please help me
