I can't program the MCU STM32L412KB
2023-05-22 3:19 PM - edited 2023-11-20 4:51 AM
I realized a custom board with a MCU STM32L412KBT6, whose schematic is attached, by using as reference the Nucleo-L412KB schematic.
The problem is that I cannot program the MCU, I am using a STLINK programmer mounted on the Nucleo F401RE (by disconnecting the jumpers on CN4 to disconnect the MCU STM32F401 on the board) and the tool STM32CubeProgrammer.
I also tried to reduce the frequency and change the mode in STM32CubeProgrammer but I obtain always " Error: No STM32 target found!".
The voltage detected in the tool is right (3.3V), the 3.3V is present also on the VDD pins e on the VDDA pin; the reset pin is to 3.3V and the BOOT0 is to 0V.
I tried also to change the MCU with a new but I obtain the same behavior.
At this point I ask you, could the STLINK be unsuitable for programming this low power micro?
Or what could be the problem?
Thanks in advance,
Tommaso
- Labels:
ST-Link
STM32L4 series
2023-05-22 4:13 PM
Check pin numbers and orientation
Check not a -P part
Should be workable with the NUCLEO
Target Not Found generally points to power or connectivity issues.
2023-05-23 9:46 AM
thanks for answer me.
The part number is STM32L412KBT6, isn't present a P character.
What does the letter p stand for?
I check the orientation, It is correct.
I don't know what else to check.
2023-05-23 11:29 AM
The -P variants use SMPS not the LDO and typically have subtle but incompatible pin configurations.
Like this situation https://community.st.com/s/question/0D53W00002GvfTNSAZ/need-nanoedgeai-library-for-stm32l412rbt6-for-my-product
2023-05-24 12:51 PM
Hi, I think I have found the problem.
The resistive array footprint used for the SWD is wrong, so I had to fix some connections on the board.
Thanks for the support.
Tommaso
2023-05-24 12:51 PM
