2022-06-09 1:08 AM
I would like to copy the exact contents of a hex file to the flash memory of my f446 nucleo, complete with byte count, address info ....
Is there any way to do this? Using ST-Link I can only find options to actually flash the hex file or manually alter single hex addresses.
Thanks!
2022-06-09 6:26 AM
Thank you all for your answers, I think I will implement some form of the AN4286 protocol after all, this also leaves it up to the master to interpret the file type and it's a well documented protocol.
Picking JWs answer as best, since this is what comes closest to be the solution for my original problem.
2022-06-09 6:27 AM
>>Why not just transmit the binary?
Or regenerate a Motorola, Intel or Tektronix HEX file data stream on-the-fly?
