KMusz.1
Hello, I would like to purchase from you an evaluation board with your STM32F407IET. Do you have any refdesign to share with this MCU? Kind regards Károly
  • February 23, 2021
  • 16 replies
  • 2825 views
I need to evaluate your MCU of type STM32F407IET
Do you have any evalboard with this device?
Kind regards
Károly
Tesla DeLorean
Guru
February 23, 2021
They don't have one for the LQFP176, there are DISCO boards with the 100 pin
Try someone like WaveShare for a close proxy.
Same die, more tested FLASH
https://www.waveshare.com/core407i.htm
Tesla DeLorean
Guru
February 23, 2021
The data sheet should have design guide type info.
There should be other boards (DISCO, NUCLEO, EVAL) with schematics, these should be sufficiently definitive. The LQFP176 obviously having more pins, and more power connection ones, the key functional pins will have different numbering but the same expectations. in SWDIO/SWCLK might move slightly and have different pin numbers, but the usage remains consistent.
VDDA, VREF+, VDD should all be wired up, ditto VSSA/VSS, the analogue domain is used by the POR circuitry
Khouloud ZEMMELI
Hello @KMusz.1​
Thanks for your question,
Actually, you can find in site all documents linked to the STM32F407IE.
There's no F407IE Eval board, but if you're looking for an Eval Board based on F407 device, there's the STM3240G-Eval, I would take this opportunity to present you the Board Selector under CubeMX which can facilitate your search:
Hope my answer helped you, when your question is answered, please close this topic by choosing Select as Best. This will help other users find that answer faster.
Thanks, Khouloud
KMusz.1
KMusz.1Author
Dear Khouloud,
Thank you for your answer!
Where can I find the CubeMX Board Selector?
I need a reference design schematic for STM32F407IET
Do you think you have such design help?
Kind regards
Károly Muszka
Tesla DeLorean
Guru
February 23, 2021
The schematics for all of ST's DISCO and EVAL boards are available to download. Go to the product pages, support tab, etc..
Design support should be sought through your local sales office and FAE (Support Engineer) out of that office.
