2025-09-15 8:54 AM
Hi everyone,
My company recently purchased a new ST-Link/v2 programmer. The problem is that after the firmware update, the device stopped working, and when I press the Connect button on the STM32CubeProgrammer, the following error appears:
Error: ST-LINK error (DEV_USB_COMM_ERR)
I tried using an ST-Link/V2 programmer I bought a few months ago, and everything works fine (I only replaced the programmer, same USB cable, same programming cable).
The programmer is original, I'm sure of it. I purchased the programmer from DigiKey.
Even the serial number I see appears to be genuine.
When I try to update the firmware, I get the following result:
Can anyone help me solve my problem?
2026-03-01 2:48 PM
Hello, i also have the exact same problem, How can i provide you a picture of the box and get mine exchanged?
2026-03-01 8:32 PM - edited 2026-03-01 8:32 PM
Do you run the update on a Mac too? Please try on a Windows PC. Like here.
2026-03-12 2:46 AM
Hi !
The solution for me was to put a plug between my Mac and the board as described in this solution.
