Error debugging with two ST link at the same time
ICohe.1
Trying to debug with two st link V2 at the same time, I started the first and then tried to start the second. Firstly I had to select the correct serial number for the second ST link but then I got the error:
Failed to bind to port 61234, error code -1: No error
Failure starting GDB server: TCP port 61234 not available.
Here is the output:
STMicroelectronics ST-LINK GDB server. Version 5.5.0
Copyright (c) 2019, STMicroelectronics. All rights reserved.
Starting server with the following options:
        Persistent Mode            : Disabled
        Logging Level              : 1
        Listen Port Number         : 61234
        Status Refresh Delay       : 15s
        Verbose Mode               : Disabled
        SWD Debug                  : Enabled
        InitWhile                  : Enabled
0 REPLIES 0
