Does STM32F042K6T6(LQF-32) microcontroller require boot pin to be grounded through resistor?
SMula
I am working on STM32F042K6T6(LQF-32) ARM microcontroller with STM32CubeMX and Keil software, according to the datasheet boot0 pin is available in pin-31 but when I open the same controller in STM32CubeMX I am neither finding any such pin nor its function like BOOT0
So should I include 10k ohm resistor at pin-31 and ground it irrespective of its availability?
Can anyone help me out here?
Shivakumar
4 REPLIES 4
Yes, you should have a pull down to ensure consistent start up performance. ​
Thank you Clive!
Even though there is no BOOT0 function available in the pin-31(PB8) as attached in the image here, I should directly connect a pull down right?
Otherwise(if I do not use pull down) is there any chances of reading garbage data from stored flash data everytime when I restart the controller?
Shivakumar
A floating BOOT pin will make your board startup into system mode (ROM bootloader) or other modes seemingly at random.
BOOT0 is not "selectable functionality" - it is the pin's functionality at startup (POR), before you application. Check the datasheet.
Thank you Ozone!!
I got your point but i'm getting confused after referring the datasheet because, In the datasheet there is no such functionality as you already said but when I open the same controller in STM32CubeMX software I found other functions in the same pin and I have also attached the image of that in my previous posts, please go through that and confirm me whether connecting pull down will affect those other peripherals or not?
Shivakumar
