ST25R3911B Hardware noise issues.
- 4 replies
- 1006 views
Hi, I am using an ST25R3911B using the ST25NFC_embedded_library in polling mode on an stm32f103CBT6. In my program, I poll my ST25 and then move on to reading values from arrays of hall sensors (4 arrays of 16 sensors each) a total of 64 sensors. The issue I am facing is that, after a number of stable and precise repetitive readings, i get a complete reading with noise in the readings. when I shutdown polling of the ST25 in my software, the noise disappears. The left sensor array is most affected by the noise.
Note:: Also the noise is not very random, every time the shift in sensor readings for each sensor is almost same as show in error log.
I have attached an image of the serial debug terminal highlighting the noise.
