2021-05-13 10:30 AM
Hi
I have Implemented lib_NDEF for st25dv04k and was able to store the ndef format, I can read it with my phone. But with my custom which uses st25r95 I m not able!
I m able to read the ndef format from a different tag st25ta (ISO/IEC 14443 Type A) from the documentation I have Implanted the reading command!
What are the commands need to be send to read the ndef format or a block of emmory for ST25TV(ISO/IEC 15693 type V) seems not the same as for A type. I find some document , trying to implemet reading a single block but nothing.
Reg suads
2021-05-16 11:47 AM
Hi Suads,
the X-CUBE-NFC3 package for X-NUCLEO-NFC0A1 (ST25R95) includes an NDEF read/write demo (PollingTagDetectNdef). This NDEF demo woks with T2T, T3T, T4AT, T4BT and T5T (e.g. ST25TV).
Rgds
BT
2021-05-16 11:47 AM
Hi Suads,
Rgds
BT
