2022-12-02 4:52 AM
Is there a Windows PC app that can read/write ST25DV04KC memory using a generic ISO15693 USB reader such as the Omnikey 5022?
I've tried wakdev nfctools, it can see the tag but can't read memory. ST25PC-NFC uses an expensive Feig reader, I'm looking for a low cost solution for our field engineers.
Many thanks
2022-12-05 5:27 AM
Hi Ben,
the ST25PC-NFC is mainly intended for ST25 Readers.
For Field Engineers, may I suggest to use Android Phone with the ST25 Tap App ? You just need an NFC-enabled Android Phone.
Rgds
BT
2022-12-05 12:36 AM
the ST25PC-NFC supports ST25R3916-DISCO, ST25R3911B-DISCO, and the RF transceiver board based on CR95HF from the M24LR-DISCOVERY.
Rgds
BT
2022-12-05 5:09 AM
Hi Brian, thanks for your reply, much appreciated
I have a ST25R3911B-DISCO, just had a play with the ST25PC-NFC app and it works very nicely.
However this "naked" board isn't suitable for our field engineers, I was hoping to find something that worked with a housed USB reader.
If that dosn't exist, then we'll have to mount these DISCO boards in suitable housings. I was just hoping for an off-the-shelf solution
Cheers, Ben
2022-12-05 5:27 AM
Hi Ben,
Rgds
BT
2022-12-05 6:44 AM
Thanks Brian, makes sense. I've been playing with the android app. We were hoping for a simple PC based solution, but the android app should do the job
Thanks again for your help, Ben
