Modify UID of ST25DV04K
toamsm
Is there any possibility for a user to modify the UID of the ST25DV04K, update specific part of memory that holds the value of the UID, or is it readonly?
Regards Tomas
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Peter BENSCH
Welcome @toamsm, to the community!
The UID of the ST25DV04K is written by STMicroelectronics on the production line and is read-only, i.e. cannot be changed. This is also mentioned in its data sheet, e.g in table 84: UID access for RF access and I2C access = RO.
Does it answer your question?
/Peter
2 REPLIES 2
Peter BENSCH
/Peter
Brian TIDAL
can you describe your application and your UID modification use case?
If you want to manage your own UID, you can use the ST25R3916/18 in type A or Type F Card Emulation mode.
Rgds
BT
