Modify UID of ST25DV04K
toamsm
Is there any possibility for a user to modify the UID of the ST25DV04K, update specific part of memory that holds the value of the UID, or is it readonly?
Regards Tomas
Peter BENSCH
Welcome @toamsm, to the community!
The UID of the ST25DV04K is written by STMicroelectronics on the production line and is read-only, i.e. cannot be changed. This is also mentioned in its data sheet, e.g in table 84: UID access for RF access and I2C access = RO.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
Brian TIDAL
can you describe your application and your UID modification use case?
If you want to manage your own UID, you can use the ST25R3916/18 in type A or Type F Card Emulation mode.
Rgds
BT
