2023-08-17 7:03 PM
Can the antenna of this board be led out for measurement? How do I lead out the line for measurement? If not do I need to rebuild the board?
2023-09-27 1:52 AM
You can find the gerber files here X-NUCLEO-NFC07A1 - Dynamic NFC/RFID tag IC expansion board based on ST25DV64KC for STM32 Nucleo - STMicroelectronics
Up to you to cut the antenna, the original design did not take in count this possibility.
2023-09-27 1:52 AM
