2023-03-23 01:24 AM
Im using the Embedded Lib.
I want one device to be a Target and the other the Initiator in every connection. Im trying to help me with the Ap2p example but couldnt fint anithing that tells me what the devices role is.
2023-03-23 01:56 AM
Hi Titus,
just change the line of
discParam.techs2Find = (RFAL_NFC_POLL_TECH_AP2P | RFAL_NFC_LISTEN_TECH_AP2P);
to have only one of the technologies to find on each device.
BR, Ulysses
2023-03-23 01:56 AM
Hi Titus,
BR, Ulysses
2023-03-23 02:02 AM
Thank you for your quick response,
Poll is Initiator and Listen is Target am �? right ?
2023-03-23 02:30 AM
Correct.
Same thing, just different specs. ISO18092 talks on initiators and targets. NFCForum uses Poller and Listener. Most of the time we are using NFC Forum terminology. But then the ISO is older and IMO more to the point in this detail...
Regards, Ulysses
