External MCU Communication by I2C
‎2014-03-07 4:34 AM
‎2014-03-10 10:04 AM
http://www.st.com/web/en/resource/technical/document/datasheet/DM00038059.pdf
Try this may be#define EEPROM_ID 0xA0 // EEPROM Device Identifier
#define EEPROM_ADDR 0x03 // EEPROM Device Address And also, make sure to externally supply
M24LR-DISCOVERY board.
thanks a lot, Have a nice day, best Regards, ST NFC/RFID Dynamic tag e2e support- Mark as New
‎2014-03-10 2:30 PM
HELLO
really thanks it is working now horaaaaa thanks leili :))))))- Mark as New
‎2014-03-10 2:34 PM
http://www.youtube.com/watch?v=48fX59xNosQ
ahttp://www.youtube.com/watch?v=48fX59xNosQ%20%20%20a%20video%20of%20what%20i%20did.%20%20leili
of what i did. leili- Mark as New
‎2014-03-18 8:21 AM
Nice video, thanks;:
‎2014-03-19 1:58 AM
Hello Leili
I also do a project by using atmega8 and NFC chip. But I am new for the I2C. So I want to ask if the code, which you posted, is all of your software to connect the atmega with NFC chip. Or do you have to write anything more? Can you you explain me what your software makes. Thank you a lot for your supporting!Best regards- Mark as New
‎2014-03-31 4:04 PM
hello,
sorry for late answer. i was in a trip. :) for atmega 48 it is all the code to connect mcu and nfc with i2c but use this eeprom address :#define EEPROM_ID 0xA0 // EEPROM Device Identifier
#define EEPROM_ADDR 0x03 // EEPROM Device Address for atmega 8 it should have little differences which i am not aware about. my application and project which is shown in the video is how to sense a sensor ( i used accelerometer sensor ) by mcu and monitoring that base on saved time by using nfc technology on the mobile phone which here is a pc..! using i2c is simple but tricky . best regards
‎2014-05-02 3:15 PM
https://www.youtube.com/watch?v=XWIHsGzYLGY&google_comment_id=z124vvdipuu1hd2ey23kcdyiawelwp4m3
