Demo CR95HF-A ISO 15963 max range
pieretti
Posted on January 23, 2014 at 11:23
I'm trying to achieve the maximum reading range from my demoboard CR95HF-A with a ISO 15693 tag (LRi2K). Until now I've obtained best results with modulation-index 10% and gain 34dB by writing 0x50 to ARC_B register: only 5 cm.
Can I improve this result? How Can I increse the antenna current?
Thanks in advance.
#range #lri2k #lri2k #lri2k #lri2k #lri2k #demo-cr95hf-a #cr95hf-firmware #cr95hf
13 REPLIES 13
pieretti
Posted on February 14, 2014 at 18:01
The M24LR-Discovery demo has arrived. For what is concerning to the CR95HF board, I'm achieving the same results. So I've decided to go further.
Where I can found the firmware source code for the SM32F103 of CR95HF board? It will be very usefull to start my own development.
Anais GALLIGANI
Senior II
Posted on March 04, 2014 at 17:34
the FW can be find in the following link :
http://www.st.com/web/en/catalog/tools/FM116/SC1444/PF253360
and then in tab ''tools & software''
http://www.st.com/web/en/catalog/tools/PF257512
Have a nice day,
ST NFC/RFID Dynamic tag e2e support
mintien2004
Posted on April 01, 2014 at 18:18
I have the same question , which solution / reader chipset / reference design that the rang of LRI2K can reach about 1m as the presentation ? Or do you have any demostration video clip ?
In case of NDA require , pls let me know , my company can sign it.
Anais GALLIGANI
Senior II
Posted on April 09, 2014 at 18:39
Hello
I advise you to contact our partner
http://www.st.com/web/en/support/rfid_partners.html
it depends of your whole system, how you use it.
and for such a read range, of course it is need to think to big power reader with big antenna.
Have a nice day,
thanks,
ST NFC/RFID dynamic tag support
