2013-12-14 03:13 AM
I have M24LR Discovery Kit.The present NFC & Data-logger android application works with NFC enable phones application. We are trying to write our own android application for CR95HF demo board for Friendly ARM board. The Friendly ARM have Three USB host. When I connect the CR95HF Demo board to USB Host, The system detects the CR95HF Board ( Friendly ARM USB controller shows STM32xxxxx). I already develop android layout only in friendly ARM to display temperature and Messages which is in the M24LR memory. I want to know how i can procedd further to develop the working application. Is CR95HF dll file helps . We check the available codes for PC Software, NFC & Datalogger application. #software #raspberry-pi #cr95hfSolved! Go to Solution.
2014-01-13 05:36 AM
We do provide some example of source code in order to develop your software, was it what you were looking for ? That you can find for example on the following page :http://www.st.com/web/catalog/mmc/FM76/CL1766/SC1412/SS851/PF251522?s_searchtype=partnumber
# Thanks , Have a nice day, ST Dynamic NFC/RFID tag support2013-12-17 12:52 AM
Hello
Yes the dll file mighthelp you, Might you please give us your email adress, either on the forum either per the online support,/st-extranet-web-active/active/en/support/online_tech_support.html
2013-12-17 04:48 AM
2014-01-08 09:57 PM
Please send me also. my email: ruixiang.xu@wtmec.com
Thank you.2014-01-09 08:23 AM
we want to try to use demo board with Java and Raspberry Pi, and Arduino, do you think it would be possible?2014-01-10 08:55 AM
2014-01-10 10:55 AM
Hi, I see in downloads just DLLs, do you have some C source or some specifications?
thanks2014-01-13 05:36 AM
