2016-11-22 09:35 PM
Hello NFC support,
We got 8700 : Frame wait time out OR no tagwhen using CR95HF to send APDU command 0xA4 to a 14443B tagwhat's possible cause and how to fix it?Thanks alot in advanced #cr95hf-14443b-reqb-attrib #cr95hf-iso14443bSolved! Go to Solution.
2016-11-29 04:50 AM
Hi Kevin,
I guess you have a wrong PCB value it might be ''02'' 1st with the command: >>> CR95HFDLL_SENDRECV, 0200A4000C020103 <<< 800602
9000296A00 As highlighted the answer of the tag is 02 Then you command write should have the PCB set to ''03'' CR95HFDLL_SENDRECV,03
00D64010BF00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF You will get the answer: <<< 800603
SW1(1Byte) SW2 (1Byte) CRC(2 Bytes) 00 The next command will be with a PCB = ''02'' the next ''03'' .... Else I think that the script error come from the fact that the lenght of datas is eset to ''BF'' whereas the DATA field have more than '''BF'' Bytes. remove all the ''00'' bytes at the end (as shown above.) Hope it will works Regards2016-11-25 08:33 AM
Hello Kevin,
Can you please provide more information on: The Tag you are using, the initialisation sequence to access the tag prior sending the ADPU command.Does the tag answer to the REQB? Thanks2016-11-27 07:27 PM
>>> CR95HFDLL_ECHO<<< 5500>>> CR95HFDLL_STCMD, 01 090468010710<<< 0000>>> CR95HFDLL_STCMD, 01 090468010700<<< 0000>>> CR95HFDLL_SELECT, 03010180<<< 0000>>> CR95HFDLL_STCMD, 01 090468010130<<< 0000>>> CR95HFDLL_SENDRECV, 050000<<< 800F5000000000000000009181E0D98300>>> CR95HFDLL_SENDRECV, 1D0000000000080100<<< 800410F9E000>>> CR95HFDLL_SENDRECV, 00A4000C020103<<< 8700 : Frame wait time out OR no tag
2016-11-28 06:37 AM
Hello Kevin,
Your init sequence is correct.The problem come fron the last request you sent to the tag.Purpose I think is to send an adpu command in ISO 14443B to select the CC file of your tag That means that you want to send a i_block which is described as follow:i-block = PCD (DID) CLA INS P1 P2 LC DATA Le (CRC) Optional in bracketin the command you sent you forget the PCD that is toogling after each adpu command (from 02 to 03 as example).The correct command might be:CR95HFDLL_SENDRECEIVE, 0300A4000C02E103and next command:CR95HFDLL_SENDRECEIVE, 0200A4000C02E103I would suggest before selecting the CC to perform a NDEF Tag Application Select with the following command:CR95HFDLL_SENDRECEIVE, 0200A4040007D276000085010100This sequence should work.CR95HF CONFIGURATION : ISO14443-B protocol >>> CR95HFDLL_SELECT, 03010180 <<< 0000ISO14443-B : INCREASE DEMOD GAIN >>> CR95HFDLL_STCmd, 01090468010130 <<< 0000REQB/SENSB_REQ >>> CR95HFDLL_SENDRECEIVE, 050000 <<< 800F50AABBCCDD30ABAB010081E1AE0000ATTRIB >>> CR95HFDLL_SENDRECEIVE, 1DAABBCCDD00040100 <<< 8004207AD100NFC SEND I-Block Tag application select >>> CR95HFDLL_SENDRECEIVE, 0200A4040007D276000085010100 <<< 8006029000296A00 NFC SEND I-Block Capacity container select >>> CR95HFDLL_SENDRECEIVE, 0300A4000C02E103 <<< 8006039000F53000 NFC SEND I-Block Read CC lenght >>> CR95HFDLL_SENDRECEIVE, 0200B0000002 <<< 800802000F9000658A00NFC SEND I-Block read binary CC >>> CR95HFDLL_SENDRECEIVE, 0300B000000F <<< 801503000F2000FF00FF040600011002000090003DED00Provide your feedbacks are welcomeThanks & Regards>>> CR95HFDLL_ECHO<<< 5500>>> CR95HFDLL_STCMD, 01 090468010710<<< 0000>>> CR95HFDLL_STCMD, 01 090468010700<<< 0000>>> CR95HFDLL_SELECT, 03010180<<< 0000>>> CR95HFDLL_STCMD, 01 090468010130<<< 0000>>> CR95HFDLL_SENDRECV, 050000<<< 800F5000000000000000009181E0D98300>>> CR95HFDLL_SENDRECV, 1D0000000000080100<<< 800410F9E000>>> CR95HFDLL_SENDRECV, 00A4000C020103<<< 8700 : Frame wait time out OR no tag
2016-11-28 06:10 PM
Hello, NFC Support,
We preceded ''00 A4 00 0C 02 01 03'' with ''03''and it answer to select command(A4), Thanks alotCurrently, we got: ''!!! Script Error : Data not compliant with dll command !!!''
The question is how to send APDU command D6 with data length 190 bytes?1. Which value should we preced before ''00 D6...'' (03?, 02? or 04? ...)2. Is there a packet size limit with dll command?The error log is as following:>>> CR95HFDLL_ECHO<<< 5500>>> CR95HFDLL_STCMD, 01 090468010710<<< 0000>>> CR95HFDLL_STCMD, 01 090468010700<<< 0000>>> CR95HFDLL_SELECT, 03010180<<< 0000>>> CR95HFDLL_STCMD, 01 090468010130<<< 0000>>> CR95HFDLL_SENDRECV, 050000<<< 800F5000000000000000009181E0D98300>>> CR95HFDLL_SENDRECV, 1D0000000000080100<<< 800410F9E000>>> CR95HFDLL_SENDRECV, 0300A4000C020103<<< 8006029000296A00>>> CR95HFDLL_SENDRECV,0300D64010BF00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000!!! Script Error : Data not compliant with dll command !!!
Thanks & Regards,2016-11-29 04:50 AM
Hi Kevin,
SW1(1Byte) SW2 (1Byte) CRC(2 Bytes) 00 The next command will be with a PCB = ''02'' the next ''03'' .... Else I think that the script error come from the fact that the lenght of datas is eset to ''BF'' whereas the DATA field have more than '''BF'' Bytes. remove all the ''00'' bytes at the end (as shown above.) Hope it will works Regards2016-11-30 06:43 PM
Thank you NFC product support5 for your advice about PCB and DATA length fix
The APDU command A4 and D6 works now.We need to repeat D6 command 25 times in our application(each with data length 190 bytes)and found there are error data byte in tag-side received data(for example reader send data byte 0xFF, but tag received data byte 0x00)Is there any other things to check in reader configuration or command flow?Your advice is very much appreciated.Thank you.2016-12-02 03:02 AM
Hello kevin
Can you provide the trace showing data transfer? Are you in chaining mode? What are the error codse reported by the Tag or the CR95HF? Regards2016-12-12 12:55 AM
Hi NFC product support5
We switch to ST25R3911 for its 1W ouput and problem solved
Current question is how to form a correct APDU read command?
Do we also need to prefix with 02/03? for example:
03 00 B0 40 10 0F 00
Is above a correct read command packet?
