Posted on May 17, 2011 at 10:17Can anybody know the shortcoming of St72141 comparing with
DSP? As I know DSP can driving the motor in wide speed range.
what is the speed limitation of driving a BLDC(compressor) motor?
If ST72141 can be used for driving IPM in low frequency (eg.3-5K)because you know low frequency IPM is cheaper than the one of high frequency?
Best Regards,
mcuinterst
