speed information
bhavin_shah10
Posted on January 30, 2004 at 11:57
speed information
bhavin_shah10
Posted on May 17, 2011 at 10:17
hi i m using st72141.
How can i use i/o ports to supply my speed information to tachometer?
or what is other way that i can display my speed information.?
BK
gaetano
if I have well understood, you are looking for something that allow you to output from your system (ST72141) the data relative to speed?
But you don't specify if the output device is a monitor (to show them), a led display or another device.
Generally, the tachometer is used as sensor 'to input' the speed...
Please, clarify these points.
Tanio
