what is the minimum Igt for BTA12-600B in all quadrants ?, datasheet provides only max values , i am in the process of replacing an existing TRIAC with BTA12-600B so I want minimum value to confirm the design will work.
‎2022-10-13 12:28 AM - last edited on ‎2023-08-31 12:15 AM by Peter BENSCH
‎2022-10-13 2:27 AM
Well, the minimum value for IGT is given in the data sheet of the BTA12 under table 2 as note 1:
Minimum IGT is guaranteed at 5 % of IGT max.
Does it answer your question?
/Peter
‎2022-10-13 2:27 AM
/Peter
‎2022-10-13 9:46 PM
thank you, didn't notice that
