VND5004A-E : Is 100A current limit per channel?
jsmith
On its datasheet, it says 100A typical for current limitation.  Just to confirm this is 100A per channel.  Thanks.
Douglas MILLER
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line.
