2025-03-05 6:39 PM - last edited on 2025-03-06 12:04 AM by Peter BENSCH
Hi Engineer,
I purchased the part STPSC20065WY, and I found the pins of STPSC20065WY are oxidized with rust stains and have scratches.
Could you suggest whether this is normal, and they are good to use?
Thanks a lot,
Suri
2025-03-06 12:11 AM
Firstly, you should contact your supplier about the problem. But as mentioned before: questions about device quality and authenticity can be submitted directly to the ST Online Support Team.
Hope that helps?
/Peter
