The pins of STPSC20065WY are oxidized with rust stains and have scratches
SuriChan123
Hi Engineer,
I purchased the part STPSC20065WY, and I found the pins of STPSC20065WY are oxidized with rust stains and have scratches.
Could you suggest whether this is normal, and they are good to use?
Thanks a lot,
Suri
1 REPLY 1
Peter BENSCH
Firstly, you should contact your supplier about the problem. But as mentioned before: questions about device quality and authenticity can be submitted directly to the ST Online Support Team.
Hope that helps?
/Peter
