STWLC38 schematics
‎2023-09-19 11:30 PM
‎2024-03-06 7:09 AM
it seems vout do not get 5V output voltage.
Understood.
What may be the reason for this. Any changes to be made in the register settings?
regards
Vivek
‎2024-01-08 12:26 AM
attach file is ok for me, please check STWLC38 relate website document
‎2024-01-08 12:37 AM
Hi, Thanks for the response. We need the firmware for this in C to be used with Nordic IC. Please provide if possible.
‎2024-01-08 12:42 AM
Dear Customer
Please find this link can be solve your issue?
https://www.st.com/en/embedded-software/stsw-wlc38fwepp.html
‎2024-01-08 12:46 AM
Dear Customer
It is simple I2C Read/Write for Nordic IC to control STWLC38,
if you need feature software support, please give your email and our local ST Marketing team will contract you.
‎2024-01-08 12:48 AM
‎2024-01-08 2:19 AM
Please refer this link for driver code
https://github.com/STMicroelectronics/STWirelessCharging-C-Drivers
‎2024-03-01 11:24 PM
The ENB pin has 360k resistance whereas in datasheet it is 10k . Will it be any issue. The device is done and we are facing some debugging issues, so was wondering if this can be it?
‎2024-03-02 5:26 PM
I find you use 360k resistance for pull down ENB pin. It can not filter some noise, we suggest to use 10K resistance for pull down ENB pin.
‎2024-03-03 3:15 AM
Oh, as per earlier okayed the same schematics we developed 20 prototypes and it will be a task now to change them all.
Can you please have a look at the other parts and let us know if anything else is to be corrected?
