steval-esc001v1 not detected
srinath mallikarjunan
Posted on July 06, 2018 at 11:51
Hi
I try to connect to the board using STLink-v2 using IAR. But i get an error that device is not connected.
Board is powered from a 12V source.
PWM lines are unconnected.
What could be the problem ?
#steval-esc001v1
kyrreaa
Posted on July 10, 2018 at 15:20
I've also had this problem until I found my connector pinning was reversed.
Check your pinnings again and again. You never know until you check twice.
Posted on July 11, 2018 at 13:35
Yes that was it..
I wish the picture they provide in the PDF was clearer.
