2006-08-20 9:42 PM
2011-05-17 1:13 AM
What would be a good solution for CAN communication with the ST7MC evaluation-kit? would it be possible in your oppinion? I want to use 5 different sensor-readings (available on a CAN-bus) to set a speed demand to a bldc motor... Have access to a stmc evaluation-kit and would like to see if CAN communication is a viable option... for me. How to proceeed? Any suggestions on doing it without implementing the CAN-bus in the microcontroller? Perhaps using a rs232 to CAN converter... I am primary interested in evaluating ''sensor reading to rpm'', not the CAN-implementation... suggestions? Thanks! /PerS
